Duce
- 11:52 PM
- Feb 6, 2016
- Roscommon, MI
Gaskets and aluminum case bolts are not available until Mid-August for 592 build. Manual states to torque to 3nm then turn 90 degrees, understand reusing aluminum bolts is a bad idea, even manual states not to reuse. Would there be a problem with just using M5 steel bolts, looking for a reason, mess with Auto-tune or just used to avoid seizing between two different metals. Or just reuse aluminum case bolts and forget it? Thoughts are appreciated!
