NPKenny
- 3:31 AM
- Jan 12, 2018
- Lehi, AZ
2015 Husqvarna 550XP. Muffler mod and smoothed ports. No port timing changes and flywheel is not advanced.
Built about 18 months ago with a meteor piston after purchasing it non-running. I had the carburetor flashed and had to replace a pto side transfer cover o-ring (thanks @cus_deluxe ). Base gasket was retained and squish was over 0.20" as a I recall.
It dies in the cut and won't idle as soon as it is warmed up. I pulled it down to pressure and vacuum test. The Decomp leaks like crazy. With it plugged there is no pressure or vacuum leak for a sustained period.
Pulled the cylinder and found the deep marks that look like cavitation around the squish band. I have had another saw I have bought like this, but not one I have built do this.
Here are the pictures. I'm looking for help on the diagnosis. Would a bad decomp cause this? I'm leery to blame the carb as it ran quite nicely for many tanks, until it didn't.
