merc_man
merc_man
- 9:14 AM
- Feb 24, 2016
- southern ontario
I had a rototiller given to me last fall and dug it out to see if i could get ot going. I ran when they put away few years ago. So i hooked my spark tester to it (kund that lights up a light bulb if that matters) and nothing. Take tester off plug and touch on cylinder head and it lights up while cranking. Think oh maybe plug is bad. Grab a new plug and same thing.
No spark either when touching plug on cylinder either. Only tester will light up.
I then tested the 2 plugs on my mower and they had good spark.
So why would my tester light up but no spark on plugs?
I clean flywheel of any rust that was on it too.
Regapped coil and cleaned it as well.
Unhooked kill wire off throttle to rule that out. Never unhookek where the wire bolts to motor. May try that tomorrow.
Any ideas why no spark on plugs but tester lights up? Thanks
