- 10:21 PM
- Apr 24, 2019
- Waleska,Ga.
How ‘bout that?View attachment 357916
Bottom of the 661 line.
I think the Tip is too narrow, the 3002 version is wider. Also the old 3003 bars are wider. So I think it is normalOk fellers , I ran one tank thru the 500i yesterday using this converted light bar and a Stihl 10 tooth .404 tip identical to @ferris setup and got the same results. For some reason the sprocket doesn’t support the chain Long Enough. View attachment 357835
Or maybe the tip is made a little wide/tall at that point for some reason.
That’s funnyThat's a design stuff up on Stihl out of the box probably a recall if they new about it. Most likely the guy putting pins in oil pumps has been move onto designing bar tips lol
That’s funny
What is the new radius?Stihl ruined their hard nose bars as well the radius is all wrong on the new bars.
This is one of the good old school Stihl hard nose bars.
That rascal’s got some meat left on it. Hardly looks used.Stihl ruined their hard nose bars as well the radius is all wrong on the new bars.
I didn’t realize the Stihl and Echo shared the same mount. I will look more closely at mine. I don’t know exactly why, but I’d have a problem leaving my 1201 outside long enough to accumulate that much snow. Lol.From tip, to bar mount. Defective heat treating and inferior/soft metal in recent stihl-born .404 bars.
Stihl is the mechanical equivalent of AIDS, it left the factory with HIV.
I've been having better luck with tsumura and GB bars in the millers:
The cuts I was making were just cookies thru about 20” maple. Very smooth deliberate cuts, start to finish w/o interruption.what are you cutting? do you do a lot of limbing and just smack the tip into the limbs. i have seen bar with wear like that from limbing all day and continuious pounding in the same spot production limbing as a chaser
