ELECT6845
- 9:33 PM
- Dec 28, 2015
- INDIANA
Saw came to me in with scored piston and cylinder and in horrible shape. I tore it apart and used a hotsy to clean it. Flushed the crankcase and lubed the bottom end bearings.
Cut the cylinder base and flange .050 and set the port timing to 100/120/76. Installed a new base gasket and Meteor piston. Pressure and vac tested. No leaks. I’ve ran about 1/2 tank of 90 ethanol free at 40:1. Piston is clean as you can see in the pics.
New fuel line, filter, carb kit.
200 on compression
The bad.
Tank is leaking along the seam I believe and will leave a small puddle of fuel overnight.
No ground wire for the coil. This coil was from a 395 and the coil will not ground out. Must choke it to kill it.
Several bolts are mismatched and been tapped to a larger size. Top cover bolts are all good. Starter cover and handlebar mounts are the ones that had issues.
The divider is from a 395 I hogged out and used since the original one was missing.
I might be missing something but I think that’s the majority of it.
Asking 450.00 plus shipping. PHO
PayPal friends and family please.
200 on compression
The bad.
