ny15
- 3:38 AM
- Jan 19, 2016
- Lima NY
Completely rebuilt 394 XP high top for sale. I bought the saw as part of a package of saws last year. I was told the coil was bad. It sat for a couple of months as I worked thru the saws. After pulling the muffler I found some scoring on the piston. I pulled the cylinder and sent it to my skinny legged friend in TN and he cleaned the cylinder up for me. I had planned on keeping the saw so no expense was spared rebuilding it. I purchased an OEM NOS piston and rings, and an OEM muffler. After splitting the cases I found a crack in the flywheel side case so I bought a new set of OEM cases. I rebuilt the carb, installed new OEM seals and bearings, new OEM coil, new fuel line and filter, new 7 pin drive sprocket and a new air filter. Saws runs perfect and oils well. I ran it 15 minutes to tune and test cut and it was flawless. Made 150 psi on my gauge. It has one small crack in the recoil cover. Other than that the plastics are perfect with no burn marks or cracks. $750 shipped pho to the CONUS.
