385 needle bearing let go today
mdavlee
Hillbilly grinder
3:06 PM
TN
You can't pop the seals off and see anything unless it went past the race any way.
Tor R
Novice, Leg model #2
9:06 PM
Mandal
I was mostly thinking when we flush a crankhouse and the risk to blast the remaining parts of the bearing into main bearings.....easier to clean without seals, can at least be cleaned both ways
Deets066
AKA Deetsey
3:06 PM
I sprayed mine out good with brakekleen, then filled with mix and ran the crank around a bunch of times. Then sprayed out with air and brakekleen again. Bearings felt great so I put some straight oil in the crankcase and ran the crank around till I got all the bearings covered and slapped a new top end on her
3:06 PM
Grenaded bearing .The most common cause of death to the Mac 10 series .AKA the weakest link .
