372xp non xtorq top end
RParrotte85
7:57 AM
Cadyville, NY
I recently repossessed my 372xp non xtorq. I'd like to put the 75cc top end on it. Is this a direct swap of piston and cylinder? Or do I need to change out other parts as well? Are they still available OEM? What's the power difference? Thanks in advance.
mdavlee
Hillbilly grinder
7:57 AM
TN
No extra parts needed. Little torque gain stock. Not as snappy either.
dustinwilt68
Wilt Built Work Saws
7:57 AM
Southwest PA
I just did this swap last week here is part number it is for an XPW 544 25 43-02. I can get them for $175.00 per kit.
Cobby08
I’m a face down ass up guy
7:57 AM
Central New Yawk...
I was told the OEM has small transfers.
Sent from my iStump using Tapatalk
RIDE-RED 350r
7:57 AM
Blossvale NY
Easily remedied. ;)
Realize the OP has an OE, but I have an XPW, my brother has an XT. Stock to stock, we couldn't tell a difference side x side in the same wood.
As we stepped into modding, stage by stage, the XPW seemed to take to mods just a pinch better. Still very close though. I would say based on our limited experience that the small difference can be accounted for by the slightly larger displacement.
I would defer to the advice of the more experienced porters/builders on whether the 372 OE or XPW takes to mods and porting better....
Of course, if you don't intend to mod it, then everything I posted is irrelevant.
Have you run a compression check on it?? That would be the first thing I would do in the course of making the decision on whether or not it needs a top end refresh. Pull the muffler and take a peek at the piston too.
Haven fun!
mdavlee
Hillbilly grinder
7:57 AM
TN
I like the xpw. It's a good bit of work to get the transfers done but they run good afterwards. The xtorq runs good when ported but it's not a racer.
