372xp clutch side bushing o-ring video is up....
04ultra
6:28 PM
Wisconsin
I've pulled apart a few that have had broken o-rings and some even missing ...Fragile little buggers ..
mdavlee
Hillbilly grinder
7:28 PM
TN
The 2165 had no sign of it left.
mdavlee
Hillbilly grinder
7:28 PM
TN
I've got 3 more cases here. I'll check them out and see if I find any later.
Tor R
Novice, Leg model #2
1:28 AM
Mandal
I think I split 4x362 and one 372 last months, 50% of them had the o ring the rest didnt have it. They are all 00-03 models and for that reason I study the IPL close, else I would probleby over seen the whole ring.
PS, your video is great with great explanation.
P.M.P.
Stiff Member
7:28 PM
Michigan
Thanks for the video I have a couple of cases to split a 2065 and a 365.
Mattyo
Youtube speciawist
7:28 PM
Farmington, CT
thanks guys! I'm workin to get better!
panteliss
1:28 AM
Europe
How long theese o-rings will keep ??? Maybe some days or something ........................... husqvarna garbages
Tor R
1:28 AM
Mandal
It looks for me to be weak spot.
I took 3×362 and 1×372 apart, 2 of them missed this o-ring.
old guy
Love me some Husqvarna
6:28 PM
Becker Minnesota
I just had a 365 apart and if I had not been reading about this o ring on that other site I would never have known there was one, all I found was the remains was a bit of black residue between the bearing & the crank.
When the clutch is tightened against the sleeve it squishes that little o ring against the bearing sealing between the sleeve & the crank, but it squeezes the o ring to oblivion.
John
Mattyo
Youtube speciawist
7:28 PM
Farmington, CT
I've built more than a few without the oring...doesn't seem to be an issue. I don't know why not....but its not. I'd rather use it, but if you don't have one, I'd put some 515 or 518 on the inside of the bushing and just go for it
