SOLD 372 xpg
Josh0619
8:22 AM
Bagley mn
saw #1 runs , has tiny smear on the exhaust side of piston. Needs a throttle cable, exhaust shield for muffler and it needs the cylinder av mount With ground for the handle. Carb heater is also missing
Saw#2 does not run, case has been changed at some point, looks oem
Needs: piston, main bearings,av mount with ground connector for handle heat. This saw does have the carb heater. cylinder is good accept a tiny dent on bottom of intake port,which could very easily be blended.
$475 shipped in the lower 48 for the 2 pho
Josh0619
8:22 AM
Bagley mn
More pics
8:22 AM
Is that 575 for both or one?
8:22 AM
