372 oe piston options
Ronie
7:25 AM
NC
I've put a non windowed 268 piston with a pop up in a couple of saws and I think they gave a little more torque over the stock piston.
Kiwioilboiler
346 Pic Examiner
11:25 PM
Marsden Pt, NZ
Sweet. I've got 160psi at sea level with just 15 minutes unloaded running. What'd the 268 saws squeeze?
cuinrearview
Handy dood
7:25 AM
Dowling, MI
Why not find someone to knock a little off the base of the jug to set squish with whatever piston you want? Wouldn't neccesarily need a lathe to do that if a fella knew what's what with a mill. Of course the timing would need to be at least looked at after...
Kiwioilboiler
346 Pic Examiner
11:25 PM
Marsden Pt, NZ
In a perfect world that'd be the ideal, but I don't have anyone I can rely on to do that work locally yet.
So in the meantime I'm all about chucking together good component choices lickety split and knowing that "I did it".
Kiwioilboiler
346 Pic Examiner
11:25 PM
Marsden Pt, NZ
Them numbers are right after they were put together, so they still had a light coating of oil in the cylinder.
Never occurred to me to check at that stage of the build, felt sure it'd be sweet FA due to the rings not having any time to bed in. I'll try next saw for kicks.
Ronie
7:25 AM
NC
Just my opinion, If I had to pay someone to cut the pop up I wouldn't do it. You would end up with $75-$80 in the piston and I don't think it would be worth it.
Jedd
11:25 PM
New Zealand
Hi Adam. Shame I didn’t see this earlier. If you stihl wanted to try a 268 windowed piston, i have a farmertec one in the garage that has a small pop up you could try. Went well in the cylinder I was using but I have now trying a big bore with a pop up husky 180 piston as a bit of an experiment (my 372 is chinese and mostly used just for firewood and an excuse to tinker in the garage). The 180 piston has a larger pin to crown height so has a much bigger pop up. Not sure it helped much as it is one heavy piston. compression gains seem a bit lost to the piston weight a bit.
I just got the engineering lads at work to turn the pistons for me - not much that can't be achieved there if you turn up with a box of beer on a Friday arvo
Kiwioilboiler
346 Pic Examiner
11:25 PM
Marsden Pt, NZ
No worries mate. It's unlikely to get any more tutu now it's together. Good saw it is.
Where you based?
Kiwioilboiler
346 Pic Examiner
11:25 PM
Marsden Pt, NZ
@Jedd in a strange twist the 372 in question must have lived close to you at some stage. It has a Meads Mower and Chainsaws sticker on it anyway.
Ronie
7:25 AM
NC
Do you remember what the measurement was from the pin to top of the piston was for the 180 piston?
Jedd
11:25 PM
New Zealand
Not off hand sorry. Will have a search thua weekend to see if I wrote anything down. It seemed like a good idea at the time as i dont have a way to lathe the cylinder base although i could sand the squish band manually. the 180cd piston in addition to a higher pin to crown height had massively wide skirts that were also a little deeper than the 272 windowed piston. Working ok at the moment but not entirely sure of longevity. Main problem was I had to make up some little brass bushes to keep the wrist pin bearing centred in the rod - the gap in the middle of the piston bosses was much wider than the 372 item.
Jedd
11:25 PM
New Zealand
Couldn’t find any words but did find theses pics I took of some 52mm pistons. All joined by pins so can see crown height and skirt length relative to pin location. The 180-480cd piston, a windowed 272, generic am piston and The pop up piston from the hyway cylinder and piston kit. Looking at reminded me that I actually took some off the sides of the piston skirts of the CD to match the base of the transfers
