decableguy2000
Wanted OE 346 crankcase and top cover, and a couple of good top cover clips. Would consider whole parts saws but just need cases.
Ive got good set of cases like new there off a 357 and are you looking for older top cover with out primer bulb hole??Wanted OE 346 crankcase and top cover, and a couple of good top cover clips. Would consider whole parts saws but just need cases.
You're right, 357 case is not the same a 346 case.I don't think the 357 case is the same, 353 and 351 are the same. As the far the top cover it is without the primer.
I'll run model's at the shop tomorrow and let you knowI don't think the 357 case is the same, 353 and 351 are the same. As the far the top cover it is without the primer.
Sorry got busy Fri I'll check tomorrow and get back to yaStill looking
