346XP carb setting
TreeMonkey85
11:07 PM
Southeastern OH
Recently found a possibly great deal on a 2012 346XP, it had great compression and was complete except for top handle spring missing. After I got it home, it cleaned up great and the P&C looked great. It has the Zama C3-el51 carb on it. Just got the kit for it. When I get it together what should the stock settings on it be and is there anything to watch out for on these? Thanks
cuinrearview
Handy dood
11:07 PM
Dowling, MI
Remove the limiters and start out both needles one turn out from lightly seated.
Make sure it has the metal intake clamp. Delete the base gasket, open the muffler outlet as much as you can, advance the timing, and go cut a lot of wood.
