So my alternative to finding a good used crank was to send the bad crank off to get repaired.
I sent the crank to Luc at @LBracing. He did an amazing job. He replaced the rod and the bearing with new oem that he already had. Luc was great to work with and his work speaks for itself. I highly recommend him.
This is the repaired crank. It looks better then new.
