- 1:25 AM
- Dec 26, 2015
- The land of pleasant living
So my neighbor brought up his 262 that I sold to him. Said it was running fine 1 day, today he went to start it, no luck. Brought it by and I tried it, no luck. Took off spark plug, wet plug. Thinking it might be flooded, pulled it over a couple of times with the spark plug out and replaced spark plug. After a couple of pulls it tried to fire like it was clearing its throat but many pulls later thats all it would do, fire and die. I told him I suspect a coil, but it will fire. Maybe the coil doesnt have enough spark to keep it running? I asked him if it was racing last time he ran it and he said no, everything was fine. Tried adjusting the carb to see if that made a difference, no go, same results. The carb was 1 turn out on the L side. No build up of pressure in the tank, I've still got to pressure test the line, but seeing as its got fuel going to it I bet the fuel lines ok. 150 lbs of compression. Anyone have anything like this happen to them? I'm thinking about buying a cheap coil just to see if its the coil. It might be in the carb, but any suggestions? I'm all ears.
