SOLD 262 project
Redfin
Meh...
3:11 PM
Central Pa
This one came to me last week and Im good onprojects so down the road it goes.
Piston has wear marks but no scoring/transfer I can see. Its blowing right at 140 psi. It popped on a prime but the starter rope broke trying to tug it to run. Has decomp jug and 120 carb. Bearings feel good.
I cleaned it enough to see what it needs. Heres what i found.
-fuel line is toast
-rear av spring is broken or weak
-needs chain tensioner
-brake band is broken
-clutch cover broken on bottom edge
-starter cord needs replaced
-switch wire to coil needs attention
Did not find any stripped holes or other damage. I will include a decent 20" 3/8 .058 husky bar and roughly half used chain. Also will send a new Caber ring.
Price is $240 to your door in lower US. Other locales we can discuss shipping. Im pretty firm on price, I will throw it on shelf for later if it doesnt sell. Thanks
mdavlee
Hillbilly grinder
3:11 PM
TN
Complete project saw here.
Redfin
Meh...
3:11 PM
Central Pa
Saw was delievered today. Griffonks what are you seeing?
mdavlee
Hillbilly grinder
3:11 PM
TN
Bill is a 262 hoarder. ;)
Redfin
Meh...
3:11 PM
Central Pa
If he saw sumptin i didnt id like to know to tell the new owner.
exSW
'Cause Thomas is a poopyhead
3:11 PM
United States
It's called a seal collar #503544201
Goes around the manifold between the carb and cylinder. Seals of the carb box between the bulkhead and engine cover.
$6.41 from the dealer.
KZ1000
3:11 PM
Ohio
I might have to break out a couple 262's and post them for the people that missed out.
Redfin
Meh...
3:11 PM
Central Pa
Gotcha, thanks.
KZ1000
3:11 PM
Ohio
Actually just fired it up the other day, got some interest?
trooney
Admitted Woodaholic
3:11 PM
The land of pleasant living
I'll check it out John. Haven't had time to get into it but will later this week. Gotta tear off cylinder anyway to put on new ring.
griffonks
1:11 PM
Boulder, CO
Those collars that fit around the intake are all crumbling in the older 262's. I started to clean one the other day to see if I could epoxy it together and it crumbled under a toothbrush's pressure with a light degreaser. So I ordered 4, they will be discontinued when the stocks run out.... This one was heated when an airleak developed at the gasket between the intake and the KS cylinder. It was the oldest HD87 262 I have ever come across.
