200 series husqvarna
rfarr94
OPE Member
4:06 AM
Powhatan va
Will any other full wrap handles from other series bolt up to a 200 series husqvarna? I’ve seen the video where a 365 wrap is cut and made t work but wondering if there is anything better? The 394 wrap handle the bottom looks like it would work but I’m sure the bolts don’t line up. Anyone found anything for 200 series saws that work?
NPKenny
1:06 AM
Lehi, AZ
576xp is very close for a 272. I have one bent together on a 272. I couldn’t locate a bottom spacer, so I had to weld a bit.
576xp fits better than a 372 because the bottom of the wrap is not offset.
395 is tough to fit because the chassis width is quite different at the support bar. The wrap itself is not bad.
There are a few challenges.
rfarr94
OPE Member
4:06 AM
Powhatan va
Thanks for that. That’s good to know about the 576 and pretty much what I was expecting for the 395. I need to get a handle and mess around with it some.
82f100swb
3:06 AM
Dryden, ON, Canada
You need to be far more specific than 200 series. That could be a whole lot of different saws of a few different chassis.
Please identify by the actual model, or at least the chassis (162 for 266/268/272 etc)
rfarr94
OPE Member
4:06 AM
Powhatan va
Yeah I should have specified I meant for the 272 chassis
srcarr52
4:06 AM
Iowa City
I've put 372 full wraps on the 272 chassis before. It takes only minor bending of the rear arm and drilling a new holes. One of the front mount holes lines up and you have to flatten a spot and drill a hole for the other.
This is on a JRed 670 so I had to weld an extension on the rear mount, on a 272 you don't have to.
davidwyby
Rural desert logging
1:06 AM
Extreme Southeast CA
We are getting started making wrap adapter spacers for 266/272. Maybe we could make some that will fit the later model wraps.
rfarr94
OPE Member
4:06 AM
Powhatan va
That would be nice to have some other options. So I guess instead of welding the bottom like in the pictures above you would bolt to the wrap adapter instead?
srcarr52
4:06 AM
Iowa City
The 372 full wrap is welded from the factory.
davidwyby
1:06 AM
Idk about these things
You mean like a 394-5 full wrap?
272 wrap on 266 I think. Guys had wraps missing blocks so we’re making some. Maybe we could mod the block design to fit 572 and 372 wraps instead of having to fab them.
