RIDE-RED 350r
- 6:36 PM
- Feb 8, 2016
- Blossvale NY
I am fiddling with a 575xp that I did a complete overhaul on and a carbed 576xp that I did a carb kit on.
Both saws seem "cold blooded" on startup. The usual full choke, pull till it pops, release choke and fast idle startup doesn't really happen with these. They will start briefly on fast idle but then die. They will do this 3 or 4 times before they will stay running. Once they stay running and after warmed up they seem to run fine in the cut and idling. I replaced the carb on the 575 with a 576 carb as I was told the 575 carbs were problematic and the 576 carb would be a good upgrade to address the issues.
Now when I rebuilt the 575 it got new crank bearings and seals. I have not built/bought a leak tester yet, but I really don't think this is an air leak issue because once they get past that initial cold bloodedness on startup, they both cut and idle fine.
I got the 576 handed to me with an acceleration issue, not so much the cold blooded start up issue. I put a carb kit in it, set the metering lever height, and after tuning it seemed good to go. I gave the saw back to the owner and it now does the cold blooded issue the 575 does. This is strange to me and I understand that I missed the cold blooded startup issue with the 576 as once it was warmed up prior to final tuning it started fairly normally cold. Again, I really don't think this is an airleak issue as once they get past that initial cold start hiccup, they idle stable, and cut fine.
Am I missing something here?? I have not experienced this issue with older style saws
