- 1:37 AM
- Jan 8, 2016
- Farmington, CT
Got a crankcase here that is freshly assembled...starter and flywheel. Package deal $150 shipped to lower 48
The good.
Case is solid..... good av mount spots ...no visible cracks. Crank is used but no vertical play or cracks in the cage.
Fresh nachi bearings.... fresh or rings. Oiler has been dismantled and reassembled. Hyway seals. Oem nos gasket kit included. Starter is freshly assembled. Solid ....missing minor pieces of plastic.
I also included 4 starter bolts.
Ugly....
Case has some rash and top bolt holes are helioiled. They look stable so I didn't touch them.
Flywheel missing a fin
Starter missing a fin or two.
Overall if you have a saw that is rough and needs a new bottom end this would be a fine start.
The good.
Ugly....
