lilbenny
New OPE Member
- 1:50 AM
- Apr 22, 2017
- Clearfield, Pennsylvania
I know, got me thinking it might work just fine. Would like to confirm it first though.The 357 and 359 ,use the k095 mount
Do you have a small mount husky saw to try it on other than your top handle ?I know, got me thinking it might work just fine. Would like to confirm it first though.
I just have a 359. Im looking for a 16" bar that is 3/8 for it and I came across that techlite bar, but it is for the top handled saws. Through searching I found the bar is a small mount, but everywhere I look it only confirms the bar will fit the top handled saws and not any other saws.Do you have a small mount husky saw to try it on other than your top handle ?
If it says k095 it will fit the 359I just have a 359. Im looking for a 16" bar that is 3/8 for it and I came across that techlite bar, but it is for the top handled saws. Through searching I found the bar is a small mount, but everywhere I look it only confirms the bar will fit the top handled saws and not any other saws.
Yes it is lo pro. Ive been debating on spending that kind of money on a lo pro setup. Would rather have tru 3/8. Anyone ever have experience with the lo pro?Something to be aware of, I would think that bar is 3/8lp, not regular 3/8 that your 359 is most likely set up for...
Couldnt I just run a standard 3/8 chain on that bar?
if your looking for a light weight bar there are better ones out there than the Tech Lite in my opinion. You would have to change the nose on it to run standard 3/8.
Thanks for the reply man, info and advice. What other options do I have? Ill prob just end up getting a Husqvarna barJust go true 3/8.
There is something different in the bar mount on the tophandles. I can't remember what now. I altered this stihl bar to fit a 338 and had to change it more to fit the 346.
No
I wouldn't bother with a 16" lightweight on a 359.[/QUOTE
Just go true 3/8.
No
