Gary Courtney
- 2:05 PM
- Jan 5, 2016
- Froglevel
just bought a poly and now I need the crank.What part # on the flywheel do you need ?
do you know if an early 066 coil will work on a newer 660?That is early 066 flywheel and 066 064 crankshaft. You shouldn't have any trouble moving that at all especially if it's a dual key way flywheel
1122 400 1311What's the part number
I am putting a 1122 400 1217 poly flywheel my other 660 has 2 bolt holes the coil I am wanting to use is 3.It should I believe
it is singleIs this a dual or single key Gary?
What's a 661 strokerYou'd think this would be snapped up for a 661 stroker.
