psuiewalsh
Basement Bodging
- 5:34 AM
- Dec 23, 2015
- Nottingham,pa
Looking to sell to fund some other projects. The 064 has new seals. It HAD an aftermarket 066 cylinder that ate a wrist pin clip. Replaced with an OEM 066 flat top cylinder and OEM piston. The saw has a factory metal base gasket and is pushing over 150 psi. The case has timeserts in it at 6mm. The handlebar is AM and the previous owner put larger diameter screws in it. The plastic mount above the handle bar had a crack that was fused and covered with stainless mesh and epoxy. I have 25" hard nose and used 28" and 32" bars and chains available separate. Looking for $425 PHO buyer to pay shipping.
