WANTED 044/046 parts...
Red97
7:57 PM
MI
Looking for
10mm 044 crank
046/460 oem stock cylinder.
Have $$ to trade
7:57 PM
Let me know a price on the crank.
And if you find a jug.
Thank you.
JJ may have been the one I mentioned in your other thread. @jacob j, was it you that mentioned fitting a 12mm crank in a 10mm case? On some, the counterweights bottom out. On others like mine, the lower part of the rod bottoms out on the case
7:57 PM
@jacob j. ^
jacob j.
Only the weird
4:57 PM
Coastal Oregon
Yeah it takes a lot of work in some cases to make the 12mm crank fit in a 10mm case. The early 10mm cases are really tight and with those, it's better just to find another 10mm crank.
Red97
7:57 PM
MI
That a 10mm crank you have for sell?
Cracker Boy
Fl cracker
7:57 PM
Florida
125454553 to 129583701 were 12mm cases with 10 mm cranks and the 12 crank will fit prior to 125454553 were the early 10 mm cases with 4 mm screws and 12 mm crank will not fit. after 129583701 were 12 mm cases with 12 mm cranks. I have had disagreements with this but i know this for a fact an old stihl tech 40 years exp told me this and i can speak from expeiriance cuz my 12 mm saw serial number has an earlieir serial number then my 10 mm saw . It threw me for a loop cuz when i got my 12 mm saw and tore it down it had an aftermarket crank that was 12 mm but serial number was saying it was a 10 mm saw and i built it back with oem 12 mm crank and ks cylinder i had being i allready had a 10 mm ks saw i wanted to build a 12 mm with 10 mm cylinder just sayin
