Willard
- 4:01 AM
- Apr 13, 2017
- Manitoba
Thankyou so much.Ok, thanks, have been curious! The trx is 100mm 100mm and 90mm on the exhaust the 92-01 is square at 100mm it must be the 85-91 cylinder that can swap
I did a quick weight on the 01 crank, it was 8 pounds 4 ounces, digital bathroom scale so it may not be perfect
So my crank might be 3/4 lb lighter, that's alot. Probably why the 1983 CR250R was the quickest on the hotshot against other brands that year.
The wider cylinder stud base is another positive, more room for a big bore sleeve maybe.
