67L36Driver
- 10:49 PM
- Jan 18, 2016
- Missouri
I’ve speculated for years I thought a saw, especially an elderly one, would run on Coleman fuel or white gas.
Summer of ‘62 two seventeen year olds had a home made ‘go cart’ but the lawnmower can was empty. Found a can of Coleman fuel in the garage. Burned up the contents going up and down the street.
Rich’s stepdad was not happy.
Neither was the mostly worn out Lauson four smoker.
Label claims the contents is Nhexane plus a rust inhibitor.
Saw collection produced a specimen ripe for tinkering.
Wards 3.6”/Remington PL-4A, 59cc x 16”. 3/8 chisel.
Mixed exactly 16:1.
Baseline and carb adjusted with 93 E free from the BP station at 40:1.
Dumped and refueled with the Coleman mix. Started and ran with no carb adjustments.
Ran it free load a good while to purge the Christian mix.
Ran and cut fine. Maybe ran a touch faster. Leaned on it heavy.
Got a little ‘run on’ at shutdown. I should have let it idle longer and cool off maybe.
There you have it [mention]JimBear [/mention]
Mixed exactly 16:1.
