- 10:44 PM
- Dec 1, 2015
- Ormond Beach, Florida
Her thighs squeezing my ears works wonders.
Yeah, I pulled up a video yesterday on YT on how to install the foam plugs... I've used them a few times in the past and they didn't work well ... well, that's because I didn't roll them the right way. Now I know better. I also recall the pressure of the plugs made my ears hurt, that's why I got the Howard Leight - the listing said they were good for smaller ear canals. Well, see.I find the foam ones mess up my ears if I wear them for more than one day so I prefer muffs. Make sure you install the foam ones correctly: twist the plug to compress it, then reach with your right arm over your head and pull your left ear upwards, then use your left hand to slide it right in and use a finger to hold it in place while it expands to block your ear. Repeat for the other side.
For muffs I really like the 3m Peltor Worktunes Pro. Good sound reduction and includes Bluetooth. I upgraded my helmet to the 3m Peltor 5x5p which have a high NRR rating but I've been disappointed with them. They're hard to get a perfect seal around your ear and if the seal is not perfect they're useless.
Using earplugs daily, I’m now able to install them with one hand, rolled and installed. It takes practice, but can be done. Also, I’ve found that the plugs only put pressure/hurt my ears when they are installed too deep. If my ears start to ache, I just ever so slightly pull them out a touch and that relieves the pressure.Yeah, I pulled up a video yesterday on YT on how to install the foam plugs... I've used them a few times in the past and they didn't work well ... well, that's because I didn't roll them the right way. Now I know better. I also recall the pressure of the plugs made my ears hurt, that's why I got the Howard Leight - the listing said they were good for smaller ear canals. Well, see.
I have their plugs too. They stay at work if needed. They do hurt my ears after a few hours, even after trying all the different sizes of plugs. Guess I got an odd ear hole or something.I have their ear plugs with the Aware tech. Pretty great to listen to music but most of the time the outside noise is too much for the Aware portion and all you hear is click, click, click of it clipping the sound so I usually shut that function off.
Love my worktunes but not with my saws.i really like the 3m worktunes bluetooth earmuffs. i find i can have those on while mowing/blowing and listen to music at a lower volume than i need to have it in my truck haha.
I use the Pro Fo Sho 34db muffs when i shoot and foam plugs for anything else.
That was quick - SOLD! $20 including shipping, new in box Teal.Sounds good - light weight.Products
www.proforsho.com
Found some on ebay. Made an offer.
Agree. I wear the 3M when mowing and tractor work. Walkers when shooting. Helmet with muffs for chainsaw work. I have tinnitus and whatever you do, wear something.I find the foam ones mess up my ears if I wear them for more than one day so I prefer muffs. Make sure you install the foam ones correctly: twist the plug to compress it, then reach with your right arm over your head and pull your left ear upwards, then use your left hand to slide it right in and use a finger to hold it in place while it expands to block your ear. Repeat for the other side.
Same here. It's also easier if the plugs are new. Used plugs also do not block the sound as good.Using earplugs daily, I’m now able to install them with one hand, rolled and installed. It takes practice, but can be done. Also, I’ve found that the plugs only put pressure/hurt my ears when they are installed too deep. If my ears start to ache, I just ever so slightly pull them out a touch and that relieves the pressure.
I have found that it seems like the ear wax itself softens them up after repeated use and then they don’t work as well - usually notice because they expand faster and they get harder to put into my ears.. BUT, a trick another logger taught me was to put used ear plugs into your jeans pocket and run ‘em through the wash - the wax gets cleaned off and they last longer.Same here. It's also easier if the plugs are new. Used plugs also do not block the sound as good.
Every time mine get run through the wash, they will not squish and stay squished. Plus, they get really soft. They do come out nice and clean though! I think its the kind I use now. I have had pairs that you could wash and it worked fine afterwords.I have found that it seems like the ear wax itself softens them up after repeated use and then they don’t work as well - usually notice because they expand faster and they get harder to put into my ears.. BUT, a trick another logger taught me was to put used ear plugs into your jeans pocket and run ‘em through the wash - the wax gets cleaned off and they last longer.
Thanks. I bought the HL corded yesterday on ebayThere are a couple of brands that are similar styles of foam noise suppressors that I've had good success with. Both will roll, insert (easily) and stay in as long as they HAVE NOT been run through the washer. I usually prefered uncorded, as they seem to stay in my ears better when wearing additional ear muffs or MC/snowmobile helmets.
I'm not endorsing either of these ebayers, just using their product pages as reference. I would do a search for the products and obtain from where you feel more inclined.
Preferred, with or without cord Howard Leight LL-1 Uncorded Laser lite,
or the Moldex 6604 Foam Spark Plugs NRR33 .
I've used both for what seems like more than 20 years.
Thanks. Found some on ebay, new, $19 free ship from NC.
