What's on your bench?
beaglebriar
The Peanut Gallery
3:31 AM
Warren Center, PA
039 rebuild... chicken chit into chicken salad.. maybe?? lol
Cleaned up the cylinder. Might as well grind on it.
Widen and square the intake, widen exhaust a bit also. Just roughed in.. I'll finish it tomorrow.
Duane(Pa)
It's the chain...
3:31 AM
Centre County
MS362 M-tronic with a scored piston. Tree guy I know who takes real good care of his stuff. Vac/pres tested before tearing it down and it was tight as a drum all the way around. Good mix. Didn't lean out from an air leak or get straight gassed. No significant transfer on the cylinder, but some gouging below the exhaust port.
I did find the air filter loose and some fines in the strato intake but no scoring on the intake side of the piston, just the exhaust side. I also found this under the piston crown. I'm guessing carbonized debris ingestion from the loose air filter and the piston damage is related. I've never seen carbon buildup under a piston before.
Thoughts / opinions?
I have to think you may be onto something with your diagnosis. Maybe @drf256 will show a pic of the 562 piston once he has it apart. The 362 piston in your pic sure has an aerodynamic shape. Just wonder if Husky has a similar evolution.
beaglebriar
The Peanut Gallery
3:31 AM
Warren Center, PA
I'd guess it got hot...burnt oil.
PogoInTheWoods
3:31 AM
Ohio
No way for oil to get there without a crack in the case or a bad gasket. Bottom end still well lubed with mix when I pulled the cylinder and no evidence of excessive heat on any of the components that would typically show it in a meltdown.
Nice work on that 039 cylinder, btw. Needs a popup now. LOL
HLS has the Cross on sale today for like 8 bux or somethin' like that.
beaglebriar
The Peanut Gallery
3:31 AM
Warren Center, PA
Mix oil collects under the piston during normal operation. Something like cutting with a dull chain on a hot day could cause it to burn under the piston with the added heat.
I have a cross pop up to put in the 039.
PogoInTheWoods
3:31 AM
Ohio
Maybe so, but I've never seen this before even in completely seized top ends. As mentioned, there was no evidence of a severe heat condition, just debris ingestion. Even the rings were still free. That said, and keeping in mind this is a strato saw, I can see fines collecting and baking to the underside of the piston crown when injected through the strato port but not making it all the way through the exhaust cycle (even though that would happen toward the end of it) -- unlike being sucked straight through the intake and blown out muffler after combustion.
All I do know is an OEM top end for a MS362 is $235 and I'm only speculating on the cause of how the original one got damaged, though I am inclined to stick with the loose air filter theory considering I can't find any other reasonable explanation. Just makes me nervous putting it back together without absolutely knowing what happened.
Don't get me wrong. I'm grateful for the input. Just hoping for something more conclusive before I commit to putting a new top end on it.
Otherwise, Hooray Hot Rod 039! LOL That thing is gonna rip.
Onan18
OPE Sponsor
3:31 AM
Georgia
Just got through short blocking this Echo SRM 265T (got replaced with a 266 short block) and all I can say is man this thing rips!!! While everything was apart I evicted the CAT and re-tuned the carb, sounds nasty to only be 25.4cc
3:31 AM
Being a strato, there is already less fuel/oil getting into the bottom end. Combine that with 50:1 and an oil that is light on detergents, and there isn't enough detergent going through it to wash it off or keep it clean.
I've seen it on 8 or 10 saws now. Not all stratos, either. In every one, they were run on 50:1 with cheap oil and probably tuned a little lean
Tor R
Newbie
9:31 AM
Mandal, Norway
Them Husky boys never gone get them 550/560/562's right...560 year 2017 week 41, blown flywheel bearing, I paid 300$ for the project.
While doing preasure/vacuum test, I got the time to put in a couple more tool kits, think I'm covered, at least for now...
went nice and through vac/preasure tests, starting & oil etc... left to dress it with a bar & chain and cut some wood
Redfin
Meh...
3:31 AM
Central Pa
Check the screen in the carb.
GCJenks204
"Special Buns"
2:31 AM
Winnipeg, MB
Damn fine looking saw you have there Tor. What do you do with all your finished projects?
