Rich Fife
Sally slap my ass
- 11:07 PM
- Mar 4, 2023
- Central New York
The bearings and the miscellaneous items should be here Sat/Sun.YZ450F
Until I get it all pressure washed I have no idea if it can be salvaged.
Bearing seats are all good so that's something
Shindaiwa 550
Piston, and crank are done. Cyl is iffy...
Might make it a 757, lol
Did it to mine awhile ago, works well .View attachment 407886View attachment 407887
Bike handlebar wrap, 266xp. Makes a nice anti-vibe handle and looks cool
I repaired the crankshaft, but, I have another one arriving today. If the one arriving isn't in better condition I'll use the one I repaired and just shim the bearing. I have a Pro-X rod ready to go.Is the shaft repaired or replaced with another one?
More under than on the bench. Finally got around to installing a drawer from my Gramps bench that I’ve dragged with me through the years. Pretty cool when you really look at it. View attachment 407969
Nice shoesBlew off a couple of boat anchors and got started on touching up the chains before they return to active duty. L-R, my 562, dad's 372, my XPW, big brother's XPW, and the little 350.
View attachment 408324View attachment 408325
Sold already. Thanks thoughFor sale?
I ran into a similar situation when I converted my 2152 to the 455 cover. The studs are just a couple threads short to me. The more useful chain adjuster is worth it though.Small improvement for OEM outer felling dog attachment on the 572XP/XPG, by including provisions of captive bar nuts.
View attachment 408626View attachment 408630View attachment 408632View attachment 408633
The stock studs could be 2 or 3 threads longer IMO with this setup. But it's an improvement for the time being.
Do you have a p/n for the longer stud? or a detailed dimension drawing?Just knock them out and replace with longer ones, easy deal.
I should have mentioned that this was made possible from the @Woodslasher shelf re-org parts.Small improvement for OEM outer felling dog attachment on the 572XP/XPG, by including provisions of captive bar nuts.
