What's on your bench?
Wolverine
dilligaf
7:26 PM
Bought this 357 brand new in ‘10. Had Dan Henry port in 2014 and haven’t touched it since. Put it on the bench to replace fuel line and filter, decided to pull the muffin out of curiosity.
3A0AEC56-A410-47BF-9AA6-C995DEED3E0A.jpeg32E8C2BD-14BB-429A-BD0A-D74738020051.jpegDE34B549-BE27-4AD6-9DDD-42A776E9DA54.jpeg
I’ve cut a LOT of firewood with this saw in the last 13 years. It’s been my main goto saw. Husky XP oil till I started milling, then RA. I did use Klotz R50 for a hot minute till I saw it completely gum up another saw. That’s probably the reason for what you see.
Kiwioilboiler
346 Pic Examiner
11:26 AM
Marsden Pt, NZ
View attachment 379687View attachment 379688View attachment 379689
You had me at "357".
Vintage Engine Repairs
7:26 AM
australia
Just finished up an old Australian made leaf blower. Nice little engine but I can’t stand the two bolt design to hold on the cylinder or intake manifolds. In this case, both were leaking because of it. I also needed to flatten the intake manifold which had warped and then made Al new gaskets everywhere from a larger roll. FEE8078B-1383-4C99-A065-78CC3E723BDA.jpeg
Matt Ellerbee
7:26 PM
Canton,Georgia
This was given to me years ago, I had it running but was missing throttle cable. Sat outside since. Decided to get back at it, rust in carb then broke the plastic fuel nipple off… crap. Chinese carb and new cable and dirt diggler is operational! Serial on motor dates it in the 80’s, figuring it was repowered at some point.
Likesaws
7:26 PM
South west. Virginia
I think that may be the original engine. I have a Troy built horse tiller wi a Tecumseh engine very similar to that one.
Same style air filter and muffler. Different gas tank.
Matt Ellerbee
7:26 PM
Canton,Georgia
It is a junior. If it is the original engine, Troy built uses excellent stickers! They are faded and mostly illegible, but still there.
I am letting the chocolate milkshake drain from transmission over the weekend, gonna top it off Monday and put to work that evening in the garden.
nbbt
6:26 PM
5543X, 5644X
Make sure you use the correct type of gear oil in those troy-builts. Many had brass gears that require "yellow" safe fluid. GL-4 and maybe GL-1 IIRC
Matt Ellerbee
7:26 PM
Canton,Georgia
The online manual calls for full replacement with 85-140 gear dope. I’ll have to look again for the GL rating, I believe you are correct though.
Matt Ellerbee
7:26 PM
Canton,Georgia
I’m having problems finding GL-4 only fluid. Any suggestions?
I have some 00 grease in the shop, would that work?
pbillyi69
4:26 PM
USA
this is what i found
PROBLEM
What lubricant should be used in the tiller transmission case?
SOLUTION
In the past the rule was: For partial fill-ups (a few ounces or less) use SAE 140, SAE 85W-140 or SAE 80W-90 weight gear oil with an API rating of GL-4 or GL-5. For full replacement use SAE 140 or SAE 85W-140 gear oil with an API rating of GL-4 only.
We have also found that 80W-90 oil with an API rating of GL-1 is acceptable for both partial and full replacement of tiller gear oils.
