Homelite410
- 2:26 PM
- Jan 3, 2016
- Belle Plaine
Clayton 1600 here
yes just burn it outside prior to install.I wonder if the Wonderwood (Volgelzang?) copies are nearly as good? I was thinking that it might make a good barn stove.
How well you do you like your Kuuma? And how efficient is it, granted that's a loaded question which is largely based off of the heat demanded by the structure(s) that it's heating?
I`m not sure either but if you are interested the folks on http://nepacrossroads.com/ could most likely lend a hand in finding it...That would be nice, but I don't know of a readily available supply of Coal in KS...
How large of area are you heating and how much wood are you using, if you don't mind? I had an air leak around my door, which caused it to use a lot more wood to heat. I heat around 2000 square feet and use right around 20 face cord per winter, using a 3300. Had a 434 before that and used about same amount of wood, but going to a smaller stove it sure burns cleaner. If it's in the 20, fill stove once a day, it's in single temps now and fill stove twice, but using 1-1/2 stoves full. The 434 held 3 times as much wood on a single full fill.Woodmaster 4400, it's a greedy hungry s.o.b., but I'm dull enough that I love cutting far'wood keeping it well fed.
Does a great job.
so would this video describe your furnaceI'm burning 18 p/u truck loads a year on average, 1200 square feet of poorly insulated old dump that could use a few windows.
No air leaks, have replaced my door gasket a few times..probably be due for a replacement next year. I also burn wood in my unfinished detached garage.
