- 11:53 PM
- Feb 23, 2023
- Montana
I have a string trimmer apart right now and was planning to do some port work for a little more power. Before I started porting I figured I better check the carb to make sure it not one of those new fangled no adjustable thing. It is not adjustable. So I am needing help to see if there an adjustable carb that's a direct swap.
In should be able to, in theory, drill out the high speed jet for more fuel as needed. But the chance of getting it nailed correct would be almost impossible, for me that is.
It's a Walbro barrel (if barrels the correct term) carb. Here's some picture of the carb, plus picture of the numbers on the carb. If you need more information or pictures, ask and you shall receive.
Thanks for any and all help.
