- 4:42 AM
- Dec 29, 2015
- Strong Island NY
Some questions on what your thoughts are on upper transfer opening angles.
I'm referring to the degree that the opening in the plating occurs. We'll hopefully discuss entry angles later.
I've only played with 2 port motors. I hope to do my first quad soon.
So on a 2 port motor, I've been opening them squarely. I've experimented with opening them at a smooth angle that opens them at 1-2* sooner on the intake side. I've also done what I called a "minifinger" (for lack of any other way to describe it) where I opened 2-3* sooner with a defined wing off of the upper heading towards the intake. I did this on a 262XP and it only has 12* of blowdown at the minifingers.
I haven't done any timed trials with this, though I should. It would be easy enough to keep raising the transfer.
I'm wondering if I'm creating a situation where the exhaust is blowing down the lip and changing the transfer spray pattern. I'm also wondering if I can use this effect to my advantage-I'm wondering if a higher placed opening on the exhaust side of the upper can push the charge more forward to creat a better scavenging loop.
Anyway, here's a pic of my 262 uppers.
I'd like a discussion on thoughts for the above.
