afleetcommand
How could that be? Just speculating.....(maybe a little more than speculation) Had a saw waste a rod bearing. I blamed the crank.....top end survived. Built another bottom end, put the top end from saw wreck one on the second.....wasted that rod bearing in about the same period of time. SO what about a top end can perpetuate the carnage??? Guessing bore alignment. Is that possible? Stuck on an arbor on the lathe seems to support that theory. Around a .010 wobble (side to side, not front to back) measured at the base. Maybe a bit more. Picked up the anomaly first measuring from the flange to the squish band...but figured the combustion chamber could have been out...but the arbor.....a bit annoyed so I'm venting. Wasn't FT BTW. BUT now its out of my life...tossed it in the Town transfer station trash bit....so I would not be tempted to give it a third try with a "trued" up base.
Of course I'm as annoyed at myself....noted there was ever so slightly a binding at BDC..so looked and went through the usual motions but never really figured out what it was on the builds...never dawned on me to check for the top end in that way. Not with those cylinders....maybe on the lower end ones....
