Today’s adventure at Fox Hill Sawmill
Guido Salvage
Supreme saw hoeder
12:40 PM
Farmville, VA
I had noticed this walnut over the summer with the top broken out. Decided to investigate, pulled out a branch that had come down and will drop the tree tomorrow. It measures about 22” at the base, smaller than I would normally harvest but I need to mill it before the top starts to rot. By the way, I trimmed the end of that branch with my Stihl MSA140 battery powered saw.
mainer_in_ak
8:40 AM
Interior Alaska
Nice work and nice slabs!
How many hours on your Honda gx v-twin?
Many commercial pressure washer guys and mud-motor folks have had issues with electrolysis corrosion on a mini fuse behind the ignition switch at about 100 hours of use. I suspect two dissimilar metals between the fuse slot and the fuse. It gets so bad, your engine won't crank over. BUT, it is usually never that nice denso starter.
Anyhow, pull that fuse and replace once a season. Fill fuse slot with dielectric grease bud!:
*my fuse at 120 hrs. No-start issue honda gx 690
mainer_in_ak
8:40 AM
Interior Alaska
Yep that noalox is good stuff for aluminum. When I had first pulled the fuse, the inside of the fuse was so caked full of electrolysis corrosion, a new fuse was needed.
Forgot to add: fuse slot will always be clean, and sprays out easily with electrical cleaner. But the fuse itself almost acts as if it's a sacrificial anode (like on a boat motor).
Guido Salvage
Supreme saw hoeder
12:40 PM
Farmville, VA
It only has about 85 hours on it. It sat over the winter a couple of years ago and I had to replace that 30 amp fuse.
Wolverine
dilligaf
12:40 PM
Guido Salvage
Supreme saw hoeder
12:40 PM
Farmville, VA
Today’s task was hickory. I do not normally mill it and only do so if it is fresh cut due to its hardness. Got it cut up and most of it stacked and stickered. I milled it in 4/4, 5/4, 6/4 and 8/4 thicknesses.
