- 11:59 AM
- Apr 30, 2016
- Central CT
Awesome! Good to know Kevin!If you find only the cylinder, the Cross popup piston has worked well a few times for me
Looking for a choke lever and oem piston for a Jonsered 930.
Please let me know if you'd have some parts to sell !
Thanks very much...Ernie
Yea she runs real good...I'm waiting on a new clutch drum/needle bearing and sprocket .Did you get the 910 running good?
Sent from Hoskey hilltop
I threw all new lines an OEM piston and Caber rings carb rebuild kit and some AV mounts.
Ernie
I think I may have one of those as I had to replace a carb on one of those a while back and still have the old one in a bin under the bench...Any of you guys have any Husqvarna 455 parts? I've got one here that belongs to a friend. He let some dipstick work on it, and it's now missing the linkage from the carb to the strato butterfly.
I may not be able to check for it until tomorrow though.
My dealer called Bryan equipment well he said he did at least but thanks I’m going to have to make some phone calls myself and see about getting one!I show the spring (1124-145-1800) currently available for $10.99 and the clips/wedges (1124-145-1905) available for $17.49 from Bryan Equipment which is the distributor for our region.
May want to check with another dealer.
