edju1958
- 8:51 AM
- May 23, 2018
- Western N.Y.
Well fellas,I got the oil tank gasket for the 306A today & got it installed.I put a thin coat of MotoSeal on the tank halves to make sure it sealed & to hold it in place while I bolted it back together.The hardest part was getting the bolt that goes in from under the FW cover to get started.I put loctite on everything.I'd have kept working,but the rain came they were forecasting & as it was I had to bring the saw into the house to finish the last 3 bolts.Only thing left to do is put the clutch back on along with the bar & chain & the 3 screws that hod the FW cover on.I suppose I should fill it up with oil first to see if it leaks or not.
Next it's on to the miserable 3400 oiler again.I got the slotted tubing nut today also.
