Bigmac
12:48 AM
Oregon
To be honest Steve idk, I know virtually nothing about 10 series saws! I just have seen that some have a larger Venturi and have the idle screw on the carburetor, you have to drill the impulse Barb and put a fitting in the top, on some you have to change the inlet nipple as well and modify the choke arm.But I have no idea what model is the best to do that with
Steve
Excellence!
2:48 AM
Oh, then it wont be the sdc18. That has the large venturi but need an external idle screw. I think i have one of those carbs with the internal idle screw. Ill check here in a bit
fossil
3:48 AM
Ontario, Canada
The SDC 20 is the carb that came in the CP125 and I believe on some earlier SP's. Hi and low are adjustable and the idle speed screw is on the side.
I always though it might be worth a try to adapt a WB off a Super 650 or 750 Homelite or maybe an HL
Bigmac
12:48 AM
Oregon
You are correct on the sdc20, it’s a good carb, but hard to find. Some of the 10 series saws had larger carbs than the 125, and are available!
I just got done doing the wb swap in the box and v4 reeds, I test fit the 750 carb before starting 4A6F35EC-3FE4-47E8-B171-ACE7B8314580.jpeg
p61 western
Ol Mudflap
12:48 AM
GFY
I just got done doing the wb swap in the box and v4 reeds, I test fit the 750 carb before starting View attachment 214270
Now you say something.:D:D
Bigmac
12:48 AM
Oregon
Ya, mark had mentioned it not that long ago, but I hadn’t seen any pics, then I saw bellhopper on YouTube do the swap like 2 weeks ago, showed some pics and the saw running after, with a port job, looks good. I would like to try, just to know! It’s not much bigger.
but I hear ya...sorry
p61 western
Ol Mudflap
12:48 AM
GFY
Lmao zero sorry needed. It is something cool to know though for sure.
jacob j.
Lord of Cargo Pants
12:48 AM
Coastal Oregon
Saw-King told me years ago that some of the carbs for the smaller saws can be used but the jets need to be drilled depending on which carb you're converting.
Some of those carbs don't deliver as much fuel under load.
Bigmac
12:48 AM
Oregon
I was concerned about that too, I don’t know what carbs are the best to convert? Mark was happy with his, but I don’t know the model. It would be interesting to try, on my motorcycles carbs the larger engine usually needs smaller jets to preform correctly over the smaller engine with the same carb, the larger engine pulls more fuel out of the jet, but these pumper carbs are different for sure
3:48 AM
Rich knows his stuff no doubt .That's where the saw in my avatar came from .I sent him a picture after I restored it .
heimannm
2:48 AM
Dike, Iowa
It seems to me someone was asking about the McCulloch 170 welder leads a few pages back. I finally remembered to take some photos.
First up, the receptacles on the welder:
20191227_154730-jpg.783245
Notice the air/vacuum connections adjacent to the other receptacle.
20191227_154737-jpg.783246
One of the plugs, notice the two air/vacuum lines tucked in behind the plug. There is a thumb operated valve on the electrode holder to allow remote control of the throttle while operating the welder.
20191227_154807-jpg.783247
The other plug.
20191227_154825-jpg.783248
That little "canister" looking device next to the carburetor is a cylinder connected to the air/vacuum lines that are in turn connected to the crankcase. I expect there must be a duckbill or check valve in the circuit somewhere but I haven't torn in to one enough to know exactly how they work.
20191217_094157-jpg.783249
Mark
heimannm
2:48 AM
Dike, Iowa
I used the SDC18 off a CP70 on one of my SP125's with very noticeable improvements in performance using the jets just as they were. I did have to grind a little in the air box to make way for the adjustment screw and for some reason the choke would not connect but I don't remember the particulars. I only use this saw a few times a year (Baraboo, etc.) so removing the AF cover and filter to start the saw is not a big deal. A clever fellow would also notice there is no idle speed adjust screw...in this case the throttle linkage just happened to stop the throttle in exactly the right spot to provide a good idle. Always better to be lucky that to be good.
The SDC18 was not equipped with the fitting for the external impulse line but I was able to modify the fuel pump cover and found a suitable donor nipple off some scrap carburetor I had laying around. The cover was equipped with a boss in the spot where the impulse fitting was to connect.
Mark
fossil
3:48 AM
Ontario, Canada
@heimannm
I have to ask. Is the caterpillar MAC tractor heading to the museum?
PS, My SP80 or whatever it is has an SDC 18 on it. Not sure if that's a sub or original.
Frank bierce
12:48 AM
Oregon
Picked these up yesterday. Mac 895, and a 1-75. 895 starts on a prime, but dies quickly. 1-75 has some light mag rot under filter cover, and has no spark. Will likely need to clean up the points.
sawfun
12:48 AM
Portland Oregon
You'll like that 895, though with a few more feet of bar.
