- 10:43 PM
- Jan 28, 2016
- Dike, Iowa
About a cord and a half plus 60 foot of good saw log .About 15-1600 board foot .I have no idea what killed that tree .One August it just died on the vine .There should be a bit of firewood in that.
Nice score.I had this PM8200 follow me home the other day. I got around to checking it out tonight. I put fuel in it and it hit (I was surprised since I got it from a dead saw section at an old saw shop). It would rev like mad and knock off. I pulled the carb and it was like new inside. The fuel line broke upon removal so I made a new one. I put the spring back in the new line. I fired it up again and it still revved like mad. Pulled the muffler and piston looked as good as new. Upon further inspection I saw the intake boot was not connected. Two screws later and it runs like a champ! The spark screen was wrecked so I removed what was left of it. Would it be advisable to run this saw without the screen? For those who have not seen one, the screen is pretty sizable and basically is the only exit for the exhaust... The saw looks to have had very little use. It is missing the brake handle and no bar o chain. What size chain would this saw have came with? I would like to put the right size chain on it.View attachment 17358
I cannot say about the screen since I do not know the cutting conditions it will be used for. However they will pull a 28" bar very nicely and with good balance. A 460 Stihl will smoke it until you lean on them. Then the Stihl stops and the Mac keeps cutting happily. I would guess it would run a 32" bar better than the 460, but if like my 800, prefers the 28". The 850's do well with a 32", but just try and find one of those as nice as that 8200 you showed.I had this PM8200 follow me home the other day. I got around to checking it out tonight. I put fuel in it and it hit (I was surprised since I got it from a dead saw section at an old saw shop). It would rev like mad and knock off. I pulled the carb and it was like new inside. The fuel line broke upon removal so I made a new one. I put the spring back in the new line. I fired it up again and it still revved like mad. Pulled the muffler and piston looked as good as new. Upon further inspection I saw the intake boot was not connected. Two screws later and it runs like a champ! The spark screen was wrecked so I removed what was left of it. Would it be advisable to run this saw without the screen? For those who have not seen one, the screen is pretty sizable and basically is the only exit for the exhaust... The saw looks to have had very little use. It is missing the brake handle and no bar o chain. What size chain would this saw have came with? I would like to put the right size chain on it.View attachment 17358
