To put it more precisely: The stoichiometric (chemically ideal) combustion ratio for gasoline is 14.7:1 in air to fuel by mass; for methanol it’s around 6.7:1. But for nitromethane it’s 1.7:1. So if you are going to make power with nitro, you are going to have to burn huge quantities of it. Kalitta’s engines run a camshaft-driven Waterman fuel pump that can deliver up to 93 gallons per minute. The car carries 18 gallons of fuel on board, and over an entire two-minute run (including starting, staging, and burnout), the engine will consume around 13.5 gallons. “The actual run takes around 41/2 to 5 gallons,” says Jim O. Whoa. Since a typical Funny Car run lasts around 4.8 seconds, that means fuel is being consumed at approximately 1 gallon per second. Consider that for a moment: a Top Fuel or Funny Car engine burns fuel at roughly the same rate as a 450-ton Boeing 747 jumbo jet.
Something to put things in a simple perspective
