Sugi bar locked tip...
Big_6
5:19 PM
NJ zone 36, PA zone 3D
Replace it or free up the roller tip?
Tia!
CR888
8:19 AM
Australia
Step 1. Find a block of wood.
Step 2. Raise bar up a bit like ax & skim tip over wood.
Step 3. Problem fixed, now go pump some greasy stuff in hole.
4:19 PM
I like to take sticky tips to the wire wheel on a bench grinder. Make sure to use plenty of lube and use eye protection.
5:19 PM
youll wear it down to a nub
Philbert
Chainsaw Enthusiast
4:19 PM
East Dakota
Big_6
5:19 PM
Thanks all!
Let's just sit it in some hot simple green...
Thinking like a machinist or saw hack, the heat expansion/contraction never fails.
CR888
8:19 AM
Australia
Whack it with some wood you just need to unsieze it. It takes 2 seconds. Done it many times. Soaking in simple green is a waste of time...and simple green...and water. I don't get threads like this where someone asks for advice, they get it...and then they go do something no one suggested. :facepalm:
Cut4fun
Redneck Chainsaw Repair
5:19 PM
Ohio
I had a ES come in locked up. Soaked in penetrating oil and diesel. Kept smacking till it broke loose. Still out there today cutting on a 440 firewood cutter.
5:19 PM
Those ES are heavy, but darn near indestructible.
