Dolkitafreak
Dolkita686
- 9:21 PM
- Nov 19, 2018
- Central Ohio
Been working on this 346 for a hot minute now, just for some reason isn't running the way I'd like. Whole build was inspired by a redhead I ran a year ago so I wanted to give it a go.
Saw had squish and base cut (.075") and I was seeing ~185psi at my elevation, I wanted more. I then had the chamber welded and its blowing 230 now, nifty. The Jred had 240, and finger ports. My numbers (I need to check my notes but I believe I remember correctly) are 101-118-82, I am not running fingers currently. My saw and the jred are running walbro 359 carbs. Similar muffler mods (big *a-hole out the front). Jreds numbers are similar to mine (I know numbers aren't everything, starting point though). My transfer roofs are flat both main and secondary, I feel I should have angled secondary more upwards.
Saw runs okay, but wouldn't hang with the jred I don't think. Someone told me they think compression may be holding it back, so I'm gonna stick another base gasket in and see what its like. Currently winds up to 14.4ish with a little four stroke. Square work chain in the video. Any helpful advice, questions, etc. is more than appreciated.
https://youtube.com/shorts/TbfcOS2dXSg?feature=share
