- 7:22 AM
- Mar 13, 2023
- Maryland, USA
Just how different an animal is the 440 Magnum, from the 10mm 044? I'll do my best to document another project!
Clearly there's some interchange. I already know the bore is 2mm larger @ 52mm.
1st pull reveals a desperate need for a decomp. I look forward to checking squish and throwing a wheel on it after running it untouched for a bit. I see the air cleaner cover is different, but the carb shroud appears the same. I think I found a K&N that I can make fit in this build. I like the max flow filter, but for the money, and the fact that the cover is hideous... with my 100 percent success in using them, it's time to give K&N a turn. They've been incredibly durable and free flowing. I already know what muff mod to do. It definitely feels like there's not much room for more compression.....
