WDC1
OPE Member
- 11:05 PM
- Sep 16, 2023
- Northern California
I have a number of Stihl equipment that I have successfully rebuilt the engines on. The problem I'm having is a HS80 Hedger, previously rebuilt with no problems. I've recently put on a AM cylinder kit, all new gaskets, crank seals, bearings, carb.,etc. but I cannot get the engine to build over 65-70 PSI. Out of frustration I've torn the engine back down to splitting the case and inspecting every detail rebuilding with a second 34mm cylinder kit just to be cautious. The result is the same 65-70PSI, not the 110-20 that I'm accustomed to.
I should note I have used this AM cylinder kit in the past without any problems. After installing two cylinder kits on this engine, both developing only 65-70PSI, so I suspect the problem is elsewhere. Anyone with Stihl experience have any suggestions of what may cause this?
