- 6:03 PM
- Dec 30, 2015
- Centre County
75. Works with 8 and 9 pin rims. If I recall it will also work with 7. I can check and report back.
I'll take it, dm payment info?75. Works with 8 and 9 pin rims. If I recall it will also work with 7. I can check and report back. Could also shorten for you...
I'd appreciate it, I have my ported 036 running. 325 and I think a square grind chain would compliment it nicely.
Is that 036 still using the smaller needle bearing and drum setup? If so, you could use this opportunity to swap to the larger needle bearing, which is a good idea. Then it will need a 9 pin on it and this chain will fit without sharpening.
He meant shortening...With out sharpening? Is my current clutch drum is pn 1125 160 2900a
Needle bearing is .493
