Stihl 076av rebuild
Brewz
9:56 PM
Hunter Valley - Australia
Another one of the big saws I picked up for next to nothing, this one cost me $50
The old bloke who owned it couldn't turn it over and nor could I. It turns freely but stops at TDC so I figure there is something in there stopping it.
It came with a second fuel tank assembly, original flat top air filter and cover, the concrete saw tall cover with 2 new air filters, a couple new OEM AV mounts, 5 kilo's of dirt and sawdust and about 10 cockroaches.
I will post pics I take of the rebuild along the way to build a bit of a reference for anyone else who may stumble across it needing info.
Feel free to add any advice or help. I am learning as I go on this one.
Brewz
9:56 PM
Tear down:
Filter rubbers are nice and soft and the 2 x filters I have are top notch.
Everything is coated with a thick hard layer of saw muck!
It will be half the weight and run cooler than it has in 20 years when I am done
Brewz
9:56 PM
It looks like junk but it as actually very well preserved under all the dirt.
I predict it cleaning up really nice!
Mmmmmmmmmm cockroach poo. There was a small family living in there, they didn't get far.
Brewz
9:56 PM
Now......... this is where I got to.
The clutch.
I figure it is screwed on and I could not get it to budge for the life of me.
I heated it, bashed it, sprayed it with penetrating oil, heated it again, bashed it again, swore at it, swore at it again......... and it is still on there.
any tips?
merc_man
merc_man
5:56 AM
southern ontario
The clutch.
any tips?
Is it left handed thread?
Brewz
9:56 PM
At this stage I plan to put a new Hyway clutch on it because the original one on it looks very worn.
I will screw in a piston stop, get it really hot and give it a good bashing tomorrow
lwhaples
5:56 AM
Vt
Stepping in to watch the fun. Least now the workbench has a good reason for being there.
Brewz
9:56 PM
Well the clutch is off
I went and bought a 27mm deep socket and made a tool
Would the rattle gun up to max and gave it a go
Wouldn't move.
Heated it up and still wouldn't move.
Got it glowing red and held the heat on it with the rattle gun hammering away, smoke going everywhere, sparks flying, and then slowly it started to move
It is off but it is dead!
Brewz
9:56 PM
Glowing red was probably an exaggeration
The springs and back plate were though.
Crank shaft is ok
Got the jug off and it is full of bits of steel bearing race, and both bearings are shot.
Piston is okish but I haven't had a real good look at it yet.
The cylinder will be ok. It has a bit of pot holing in the squish band but should recover well
