brad ruch
- 10:51 PM
- Aug 25, 2016
- michigan
Got a Stihl 034 up for sale.runs idles oils good.compression is great.saw is pretty darn clean.i replaced the oil pump,worm gear,clutch,and clutch drum.has a 8 tooth .325 on it that I had is like new.i bought a new oem oil line kit but didn't work so well.those kits are junk.i tried heating up the tube with a heat gun 3 times to get it on the pump and all it did was trash the hose.so I installed some heat resistance nitro RC car fuel line with the brass tube from the kit and worked great.very easy to install that way.i also bought a new rope and aftermarket rotor for the starter housing.big mistake there junk.so I'm gonna order a new oem starter prawl and rope.thats all it really needed.i will have that done ASAP.i have a bar and 2 chains also for extra if wanted.$300.00 plus shipping.
Sent from my Pixel 2 XL using Tapatalk
