czar800
- 11:22 PM
- Jan 14, 2016
- Ellwood City
Did you do a pressure/vac test after you found the scored piston? Bearing ok?
Make sure it has a 3 screw carb, h l and idle. Many of these did not have an adjustable h jet.
192 or 194?Has a wt192 on it. Going to put a kit in it also.
.025 of the keyway. Most recommend .020, but I've gone as much as .030 and got more rpm. I find .025 to be a good balance.Update: dropped off the piston/cylinder at a friends to get cut. He's also going to make me a the mandrel. He's a very skilled and runs a wire edm cutting machine? He's going to make different cutting angles for the squish band 0-5 degrees just so I have then! He worked under some nascar engine builder machining stuff. Needless to say I was there all morning!
Question, how far should I advance the timing?
