- 8:55 AM
- Dec 29, 2015
- Strong Island NY
Why did you take it apart in the first place?End gap? Why do you ask?
Smarty me, I broke a piston ring so that I could clean the groove while waiting for my new rings to be delivered. New rings wrong size! uh-oh.
If you can direct me to a site that sells the package, or a complete top end, I will go that route. I haven't found that site.
Just run a top ring and forget about it. It’s a string trimmer, one ring should work just fine.
Ring end gap is a way of telling if you need new rings or not. Its a way of measuring wear. May of us run a single ring in chainsaws, which are generally higher output engines than that of a string trimmer.
I run a single 1.2mm thick ring often in Stihls, and husky’s used to come out of the factory with a single 1.5mm ring. The second ring does very little more than offer more cylinder friction. There is no oil in the crankcase to control, like in a 4 stroke.
