FergusonTO35
- 2:34 PM
- Jul 9, 2017
- Boonesborough, KY
Hit a few little snags with the rifle this weekend. I ordered a Williams FP-GR for the American, same as I have on the Henry. The receiver is grooved for tip off mounts, however the rear groove isn't cut forward enough from the factory to allow bolt handle clearance. I took a swiss file and carefully extended the grooves forward so the sight could mount forward a bit more. That done, the FP-GR mounts up perfectly.
Took it out shooting and the front sight is a wee bit too short. With the elevation bottomed out, I am still hitting about 2" high at 50 yards. I really do like the fiber optic front, and Williams makes this type in their Firesights line. Turns out Williams has a front and rear set for this rifle consisting of a WGRS rear sight and front ramp/Firesight unit. The Williams front ramp does look taller than the original, and the WGRS rear looks to sit a bit higher than the FP-GR does. The set was only $32.00 so I went ahead and ordered it. If the new Williams front is about .050 higher than the OEM sight that would be about perfect.
