Recommended grease
Boomer2230
2:48 PM
Canada
I was wondering about grease for my FS560C. Sadly it doesn't have the removable plug.
I have some Molly grease here, that should be fine for the head.
There doesn't seem to be much info for them.
MuvLuv
Active OPE Member
1:48 PM
Brooklyn
You can make your own plug by drilling a hole, planned obsolescence is getting out of hand, echo sells some good gear grease and no grease lasts a lifetime while in use.
DND 9000
7:48 PM
Germany
Yes. Believe it or not, it is like this. If you go to your workshop and have them dismantle the gearhead they can re-grease it. But for the user it is not possible to grease it, because it is made with lifetime grease filling.
Boomer2230
2:48 PM
Canada
Ok, well I didn't listen to what you said about the lifetime grease and opened it up and found a lack of grease as I figured. Pumped about 10 shots into the head and reassembled it. There is a small set screw on the head that probably can be changed out for a grease zurk.
After I put the new grease I ran it for 20 min or so and the head doesn't get anywhere near as hot as it did.
Got a few hours of work for it so I'll find out soon enough.
Thanks anyway
DND 9000
7:48 PM
Germany
Don`t overgrease it. It will get hot too if there is to much grease in it. Total amount of grease for that gearhead is 19g.
Boomer2230
2:48 PM
Canada
There might have been 1g of grease in the head left when I opened it up.
It's not a sealed unit so it doesn't pressure up when it gets hot.
Ran it for a couple of hours and it worked fine. Head didn't get hot at all.
DND 9000
7:48 PM
Germany
Uh, that wasn`t much what was left in there. Glad that it works fine now.
